Message
par gerardg » 26 déc. 2007, 13:51
A mon avis, c'est du domaine de l'impossible, maintenant...
Mais bon, qui ne risque rien...
Moi, si je craque, ce sera pour me ballader le we, alors, CG de CB500...
Avec une CG française, peu de kilométres et vraiment nickel, ça se négocie autour des 5500 - 6000 euros...
Pour revenir au pot,
voilà les réponses glanées sur un forum allemand.
Comme quoi, faire du bruit, c'est pas tjrs synonyme de gain en couple et souplesse :
Re: how work Scottmeier Edelstalkrümmer fit with stock auspuff info???
With Albert S' stainless headers mounted with stock muffler and the lean carb setting on my Californian GB500, I found the sound not much louder, but with a higher, "ringing" note (more treble) like from a smaller engine. The engine maybe revved better above 5kRPM, but also vibrated more in that range, and it definitely had less torque in the 2000;-3500 rpm range. Mind you, Albert developed these headers for tuned and 650cc engines not specifically for the stock 500cc.
In any case, all those points improved when I fitted the original header. However, perception of sound is a very personal matter, and actually the good Armin in Hessen sowmewhere, who bought my Schottmeier headers, thought his GB500 got a better sound with a deeper note...
If only you could read german, you would find more opinions about this subject expressed in old messages in here.
Bluurp, bluurp
Richard is a diplomat. Don't use it with a short stroke RFVC. This is what all the German discussons is about. With the 80mm stroke engines it might be working well.
Gérard
