Rsorder Old School RuneScape Hunter Rumors Guide: Snowy Night Butterfly Task
Posté : 29 avr. 2026, 08:52
If you’ve just been assigned a Snowy Night Hunter rumor in Old School RuneScape, you can relax-this is one of the most straightforward Hunter tasks you’ll encounter. With multiple locations, minimal gear requirements, and a simple catch method with [url=https://www.rsorder.com/]OSRS gold[/url], this task is perfect for quickly cycling through rumors and keeping your Hunter grind efficient.
Where to Find Snowy Nights
Snowy Nights spawn in four different locations, which is a high number compared to most Hunter rumors:
· Rellekka Hunter area
· Weiss
· Farming Guild
· Mount Karuulm (Mons Gratia)
A reliable rule of thumb is to head to the Rellekka Hunter area whenever it’s available. Many players treat this as their default “stomping grounds” due to familiarity and convenience. The area contains six Snowy Night spawns, which is more than enough considering you only need a single successful catch to progress the rumor.
To get there quickly, use Fairy Ring DKS, which places you almost directly next to the hunting area. It’s one of the fastest and cleanest travel routes for this task.
What You Need to Bring
Snowy Nights are butterfly-type Hunter tasks, meaning the setup is extremely minimal.
Required items:
· Butterfly net
· Bare hands if you’re 45 Hunter or higher
That’s it. You do not need jars-there’s no reason to save these butterflies. Catch them and move on.
Inventory setup:
Many experienced players use a universal Hunter Rumors inventory that rarely changes. The goal is speed and flexibility, allowing you to immediately transition to the next rumor without banking. Since Hunter rumors often feel like five-minute mini-episodes, this consistency saves time over long sessions.
Recommended Gear and Teleports
For equipment, stick to the standard Hunter setup:
· Guild Hunter outfit pieces (as many as you own)
· Graceful pieces to fill in missing slots
· Drakan’s medallion or staff for fairy ring access
· Bonecrusher necklace or Bonecrusher to automatically bury bones from Hunter rumors
· Optional extra teleports (Quest Cape is excellent for fast fairy ring access)
This setup minimizes downtime and keeps your stamina high across multiple rumors.
How to Catch Snowy Nights
Once you arrive-most commonly at the Rellekka Hunter area-the process couldn’t be simpler:
1. Locate the Snowy Night butterflies.
2. Click them.
3. Catch them.
That’s the entire mechanic. There are no traps, no timing windows, and no complex interactions. While repeatedly clicking small moving NPCs can be mildly annoying, this is where RuneLite plugins dramatically improve the experience.
Essential RuneLite Plugins
To make Snowy Night rumors nearly effortless, enable the following:
Hunter Rumors plugin
· Highlights Snowy Nights on-screen
· Shows current rumor details in a tooltip
· Provides location guidance for each rumor
Better NPC Highlight plugin
· Allows you to highlight an NPC’s clickable area (hull)
· Butterflies can be clicked anywhere from their position down to the ground
· Highlighting the hull lets you click more accurately and consistently
To use it, add the NPC name under the Hull section in the plugin, toggle it on, and enjoy much easier catches.
Drop Rates and Time Investment
Snowy Nights have a pity threshold of 150 catches, reduced to 142 if you’re wearing the full Hunter outfit. While that number sounds high, butterfly tasks are extremely fast. Realistically, you’ll spend 10 minutes or less completing this rumor before moving on.
Final Tips
Snowy Night Hunter rumors are designed to be quick, low-effort, and repeatable. With the right teleports, a consistent inventory, and the correct RuneLite plugins, they become nearly brainless-in the best possible way with [url=https://www.rsorder.com/]cheap RS gold[/url]. Mastering simple tasks like this is key to optimizing your overall Hunter Rumors grind.
Once you’ve finished, you’ll be ready to jump straight into the next assignment without missing a beat. Happy hunting.
· Weiss
· Farming Guild
Required items:
· Butterfly net
Inventory setup:
2. Click them.
3. Catch them.
Final Tips
