I've been totally losing myself in Sanctuary since this Lord of Hatred season dropped. My sleep schedule is basically non-existent at this point, but man, the discovery I made this week makes it all worth it. If you've been hanging out on Discord or Reddit, you've probably seen the chaos surrounding this new trick to protect Greater Affixes while using the Horadric Cube. I'm usually the first one to call BS on these "glitches," but I actually tried it on a 3GA weapon I was terrified to touch. It worked perfectly. If you're tired of hunting for the cheapest Diablo 4 items only to have the Cube eat your best rolls, you've gotta try this. It's a total lifesaver for anyone trying to perfect their build without the usual heartbreak.
How the lock actually worksThe steps are almost too simple, which is probably why it took us this long to figure it out. You just take your gear to the Occultist and pick that one Greater Affix you can't afford to lose. Hit reroll like you're planning to swap it, but here's the kicker: don't change a thing. Just accept the original roll again. For some reason, the game's backend flags that specific stat as "enchanted." When you head back to the Cube for a Focused or Chaotic Reroll, the Cube just ignores that locked stat entirely. I tested this myself on a +18% Vulnerable Damage roll last night. I ran five different recipes on it and that stat didn't move an inch.
Community tips and the right timingLooking at the community feedback today—it's May 6, 2026, for those keeping track—this seems most reliable when you're just trying to lock one GA. Some guys are claiming they've locked two, but that feels a bit buggy and risky for my taste. The real secret is the order of operations. You absolutely have to temper your item first. If you try to do the lock at the Occultist before you've finished your tempering, you're just asking for a bricked item. It's a specific loop: temper, then lock, then hit the Cube. Do it out of order and you'll regret it.
Why this changes the endgame grindI've managed to finish two BiS pieces using this method already, and the stress levels are way lower than the old "pray to RNG" way of doing things. Even for those high-end uniques, being able to lock down one massive GA before you start rerolling the unique power is a massive win. It's not a perfect system since you still gotta grind for Primordial Dust, but at least we have a bit of control now. If you've got a 3GA piece sitting in your stash because you're too scared to ruin it, just give this a shot. It's the real deal and makes the endgame feel a lot less like a slot machine.
Final thoughts on gearing upHonestly, this might be the best time to push your character to the limit before Blizzard decides to patch it out. If you find yourself short on the resources needed to keep up with these crafts, visiting u4gm is a great way to buy game currency or items to keep your momentum going. It's much better than spending weeks farming for a single drop that might never come. This lock trick is honestly a gift for the community, so make sure you use it while it's still live. Just follow the steps carefully, don't rush the process, and you'll be rocking a fully optimized kit in no time.
u4gm shows where to lock GAs for BiS gear fast
CrystalVibe
- Je roule en : 500SR - CFMOTO
