U4GM Explains How to Get More from Diablo 4 Mercenary Vendors
Posté : 22 oct. 2026, 10:35
Improving your character in Diablo 4 requires more than collecting powerful equipment. You need to understand how to upgrade Legendary Aspects, craft better amulets, farm valuable materials, and optimize your damage multipliers. Whether you are struggling to progress through higher Torment difficulties or looking for ways to refine your current build, these strategies can help you get more value from your D4 items and make your endgame progression more efficient.
1. Check Equipped Aspects and Find Better Gear
One of the simplest ways to improve your character is to visit the Occultist and open the Codex of Power. Search for the word “equipped” to display your currently equipped Aspects in one place. This makes it much easier to identify which Aspects can be upgraded without checking every item individually.
You can also visit the Jeweler and craft Aspect caches. These caches can provide rings and amulets with useful Aspects, including Ancestral equipment and, in some cases, Greater Affixes or Unique items. Choose your cache type according to the gems your build needs, avoiding options that mainly offer gems you rarely use.
2. Craft a Powerful Amulet
A well-crafted amulet can significantly increase your damage. Ideally, you want an amulet with +3 ranks to all skills and a combination of three complementary damage multipliers.
Use the available affix-removal and adjustment systems carefully to replace unwanted stats with more useful attributes. Since some outcomes depend on random rolls, you may need several attempts. When you obtain a valuable affix, use the Enchantress to reroll less important stats while protecting the modifiers you want to keep.
For defensive equipment, Chromatic Adjustment Prisms can help you obtain all elemental resistances. Once the desired resistance affix is established, improve its value through the appropriate rerolling system.
3. Make the Most of Mercenary Vendors
Mercenary vendors are valuable sources of crafting materials throughout the season. Depending on the mercenary and their progression, their inventories can include Scattered Prisms, gem fragments, runes, boss-summoning materials, and equipment caches.
Spend Pale Marks on useful supplies, and refresh vendor inventories when you are searching for a specific reward. Remember that leveling different mercenaries can unlock additional inventory options. Alcan, for example, can provide crafting resources such as prisms and runes, while Subo is useful for obtaining boss-summoning materials.
4. Farm Soul Fragments Through Nightmare Escalations
If you need specific Lesser Soul Fragments, focus on Nightmare Dungeons and, preferably, Nightmare Dungeon Escalations. The type of cache available inside a dungeon can influence which fragments you obtain. For example, a Ruby Cache is useful when targeting fragments associated with fire resistance.
During an Escalation, follow the War Plans route that leads to the portal branches. After completing the first dungeon, choose the portal with the cache type that matches your target. Defeat the dungeon boss and open the final chests for additional chances at valuable fragments.
Regular Nightmare Dungeons can still be worthwhile, but Escalations generally provide better opportunities for concentrated farming.
5. Reroll Ancestral Equipment Strategically
Ancestral amulets and other valuable pieces deserve special attention when using set or Horadric rerolling systems. Certain rerolls preserve an item's Ancestral status, allowing you to pursue better affixes and potentially obtain Greater Affixes through eligible methods.
Affix-value rerolls can also improve existing skill bonuses without forcing you to replace the entire item. Unique equipment may offer rerolling opportunities as well, helping you replace unwanted attributes with stats that better support your build. However, each system has limitations: Horadric rerolls do not necessarily produce Greater Affixes, and some set bonuses cannot be changed.
Always check what a specific reroll method can modify before spending valuable materials.
6. Balance Your Damage Multipliers
If you are struggling to advance through higher Torment levels, review how your build distributes damage bonuses. Three important categories are Critical Strike Damage, Vulnerable Damage, and elemental or general damage.
Stacking only one category may deliver less improvement than balancing several complementary multipliers. Weapons and off-hands are particularly useful for Critical Strike Damage, while gloves and amulets can offer more flexibility. Whenever possible, direct Masterworking toward the strongest available affixes on each item rather than automatically upgrading the same stat everywhere.
Tempering should also support your build's most reliable damage source. If your character consistently lands critical hits, Critical Strike Damage may be a practical choice, provided it complements your other bonuses.
7. Use Paragon Glyphs and the Horadric Cube
Paragon Glyphs can provide substantial additive damage that benefits from the multipliers in your build. However, defensive options should not be dismissed. If your character needs additional maximum life to survive difficult encounters, a defensive Glyph can improve both consistency and overall progression.
Finally, use the Horadric Cube to make otherwise disappointing Legendary equipment more useful. Rerolling an unwanted defensive or resource-related affix into a relevant offensive attribute can transform an average item into a strong upgrade. Focused and chaotic rerolls offer different possibilities, so select the method that best matches your goal. The Enchantress can provide another way to refine the remaining affixes.
Final Thoughts
Successful endgame progression comes from combining smart farming with careful crafting and balanced damage scaling. Check your Aspects regularly, invest in useful vendor rewards, target the right Nightmare Escalations, and avoid wasting materials on rerolls that cannot deliver your desired result. With a more efficient equipment strategy, you can strengthen your build, overcome tougher Torment challenges, and make better use of buy D4 items as you pursue your next major upgrade.
Get ready for the new Diablo 4 season at U4GM.com. Buy Diablo 4 Gold and Items with fast delivery, low prices, secure service, and instant stock for PC, PS5, and Xbox.
Final Thoughts
