In Path of exile currency, building a powerful character is an intricate and rewarding process. Players have access to a massive array of passive skill trees, gear options, and skills that can be combined to create unique and effective builds. One such build is the Kingsmarch, which focuses on powerful offensive and defensive capabilities through a blend of elemental and physical damage. The Kingsmarch build excels at sustained damage output while maintaining durability through life leech, resistances, and other defensive layers.
What is the Kingsmarch Build?
The Kingsmarch build is a hybrid offensive and defensive build that centers around physical and elemental damage. It’s well-suited for players who want to be versatile, dealing substantial damage with area-of-effect skills while staying durable enough to take on bosses and high-level content. It’s commonly used in Endgame Mapping, Bossing, and League Start strategies due to its high sustain and damage output.
Key Aspects of the Kingsmarch Build
1. Elemental and Physical Damage Hybridization
A key feature of the Kingsmarch build is its focus on elemental damage conversion. By converting physical damage into fire, cold, or lightning damage, you can take advantage of scaling with powerful elemental nodes and support gems. Some builds also rely on elemental penetration or elemental resistances to boost damage output further.
2. Sustain and Survivability
While the Kingsmarch build is capable of dealing substantial damage, it also incorporates survival mechanics like life leech, life regeneration, and high resistances to ensure longevity during tougher encounters. A crucial defensive layer in this build is Leech effects, which allow you to recover life with every hit, ensuring that your character remains alive throughout combat.
3. Attack Speed and Mobility
The Kingsmarch build heavily emphasizes attack speed and mobility, allowing you to unleash quick, high-impact attacks while moving and dodging enemy attacks. High movement speed is also important in making sure you can reposition quickly during difficult fights, such as boss encounters or when you’re navigating through tight spaces in endgame maps.
The combination of high attack speed and life leech ensures you can sustain your health during battle without compromising on damage. The ability to strike quickly also allows for high clear speed, which is critical when farming for resources in the later stages of the game.
Core Skills and Gems for Kingsmarch Build
1. Elemental Hit
Elemental Hit is the bread and butter of the Kingsmarch build. It applies a random elemental effect—fire, cold, or lightning—on each hit. When supported by the right gems and equipment, this skill can deal substantial damage, especially when you use it with elemental penetration effects. Elemental Hit works well in conjunction with attack speed and increased elemental damage passives to generate consistent high-damage output.
2. Cyclone
Cyclone is often used in Kingsmarch builds for area-of-effect (AoE) damage, enabling you to clear mobs efficiently. This skill allows your character to spin continuously while moving through enemies, which works perfectly with high attack speed and the life leech mechanic. Cyclone is great for both clearing packs of enemies and for its high mobility, allowing you to reposition quickly if you’re cornered by tough foes.
3. Vaal Pact
To increase your sustain and survivability, Vaal Pact is often taken in the passive skill tree. This node significantly boosts life leech, allowing you to recover life instantly with every hit. With Vaal Pact, you can recover health during combat even faster, which is crucial for staying alive in intense battles where you need to absorb lots of damage quickly.
Conclusion
The Kingsmarch build is a versatile and highly efficient build in Path of Exile, offering a blend of elemental and physical damage while maintaining strong survivability. It excels at both clear speed and bossing through sustained damage output and life recovery mechanics. By focusing on attack speed, elemental damage conversion, and life leech, this build can perform well in both solo play and group content, making it a solid choice for endgame mapping or even challenging bosses like Shaper or Uber Elder.
With the right gear, passives, and skill gems, you’ll be well on your way to mastering the Kingsmarch build and enjoying the powerful combination of cheap POE currency and defense it offers.
Every player needs a lot of Path of exile currency, I suggest you go to a third-party website like MMOexp.com to buy some currency.
MMOEXP POE is to destroy the orbs scattered around
Adrianayng
- Je roule en : RS7
