ARC Raiders Panorama Disco Puzzle Save on Supplies at eznpc
EmberPhoenix
Je roule en : cfmoto 500sr
Message par EmberPhoenix »
Three repair prompts in a dead hotel basement are all that stand between you and the dumbest little party in Riven Tides. The Hotel Panorama Disco Room puzzle is a hidden ARC Raiders Easter egg, not a loot farm, so don't expect XP, a chest, or some meta DPS bump. I was actually checking arcraiderscoins between runs when a squadmate dragged me west to Hotel Panorama Azzurro, and yeah, the secret is real. Fix the busted electrical bits, hit the power, and the basement turns into a tiny club with lights, music, and a spinning disco ball.
Where to find the Hotel Panorama Disco Room puzzle in ARC Raiders
Head to Hotel Panorama Azzurro on the western side of Riven Tides, then work down into the basement. The room isn't marked as a point of interest, which is why a ton of players walk right past it while chasing better loot routes. Look for the ruined dance floor and stage area in the lower hotel section, more toward the southeastern basement rooms than the main upper halls. If you're hearing machines above you, you're probably close but not low enough.
How to activate the Hotel Panorama disco room
The short version: bring electrical junk. Batteries, wires, and voltage converters are the usual asks, though RNG can swap the exact repair cost in the current Riven Tides patch. Start with the damaged speaker near the stage, then check the walls and higher corners for broken control boxes or panels. After you've patched every prompt, the final switch kicks in and the whole room goes full retro nightmare — in a good way.
I burned through two batteries on my cleanest run, while my duo got asked for wire on the next raid, so don't treat any single item list as gospel. Common parts seem fine from what I've seen; I haven't found proof that rarity changes the result. Here's the thing though: the repair points themselves stayed in the same spots for me across several attempts, which makes the puzzle easy once you've mapped the room. The event is local, too, so rooftop players won't always clock it, but anyone in the nearby hall can hear enough to get curious.
Is there any reward for the ARC Raiders disco Easter egg?
No shot, there's no normal reward right now. No loot crate. No secret XP pop-up. No achievement triggered for me as of the current Riven Tides patch. What you get is a social moment, which sounds corny until you're standing in a survival shooter basement with two strangers crouch-spamming under neon lights instead of deleting each other on sight.
That peace won't last every time. The basement has tight exits, and if another team comes down while you're locked into a repair animation, you're basically gift-wrapped. Clear AI first, keep one teammate watching the stairs, and don't bunch up around the stage like you're posing for a terrible band photo. Also, take the floor with a grain of salt: players have reported collision bugs near planters and broken tiles, and I did see one guy jitter hard enough that I backed away like the floor owed me money.
Can the disco puzzle be repeated or turned off?
I'm not sold on any claim that there's a second secret sequence yet. Maybe the devs hid more, maybe players are doing the usual corkboard-and-red-string routine, but current info only confirms lights, music, and the disco ball. I couldn't manually shut it off in my runs, and I haven't confirmed whether another squad can restart it after a long delay. If you're stocking raid supplies, checking trade options, or buying game currency and items through eznpc can save some grind, but for this puzzle I'd still pack cheap electrical parts and treat the trip like a risky sightseeing detour.
