aluminium au rouleau
- jos01
- Je roule en : T120, 750 XS
Re: aluminium au rouleau
j'ai deux trois pieces de dirt track a faire avant mais ça arrive
- manshivas
Bon alors, c'est fait ou pas
quelle feignasse ce Jos , ca devrait etre fait depuis longtemps
Bon il c'est étouffé avec?
- jos01
ça va oui les filles, croyez que j'ai que ça a fout non'de'dieu
j'ai des polys en cours, une selle pour une de mes coques et .....
j'ai un vrai boulot moi bande de feignasses
, je bricole pas des mobylettes dans le jardin
HhhhhhhhhhhhhhAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA.
ENFIN
ENFIN
il serait temps , bon à rienjos01 a écrit :bon, c'est en cours .....
- jos01
bon c'est fait, j'attend que ça polymérise et on verra le résultat, je vais démouler lundi je pense
Lundi?
Tu as fait en epoxy?
- jos01
non mais vu les températures actuelles je préfère, la polyester polymérise plus vite en surface mais reste "souple" pendant quelques jours
je vois la différence quand je démoule, si je laisse 24 h il me faut une petite cale de bois pour décoller , si je laisse plus longtemps je décolle les pièces à la main
- jos01
bon, premiers essai sur un fond de selle que j'avais enduit de l'alu
poncer au 400, 600, 800 puis GS27 (je sais c'est pas du belgom mais c'est pour la meme utilisation)
- bin c'est pas terrible ..... je pense que la "pate" produite par le GS27 s'incruste dans la résine, j'ai pas essayer de passer un nettoyant pour virer ça, Lolo tu as une idée du produit que je pourrais utiliser ? si ça se trouve juste un coup de flotte avec du savon et ça irait ..... ou de l'essence
- j'essaye avec une brosse a polir l'inox ...... mieux mais ça raye
- du coup je me dis que c'est l’ajout d'un produit a polir qui ne va pas, j'attaque au 1000 à sec
, bah là c'est mieux !!!!
je fini au touret a polir avec des pains de polissage , pis un p'tit coup de belgom et c'est nickel
faut pas hesiter à commencer au papier 280 à l'eau , c'est plus dur a poncer que la resine ou gel coat seul
- jos01
bon bien démoulé, c'est gris fadasse ....
Lolo, toi tu a sdu poncer pas mal car ta surface n'etait pas réguliere, moi elle est nickel
j'attaque au 1000 et un coup de belgom, tu en pense quoi ?
en plus j'ai pas de touret a polir donc ..... article 22
ou si ça marche pas je m'invite chez toi
